Firebird Rear Hatch and Headlights
Old Feb 22, 2020 | 05:04 AM
rgauder's Avatar
Car: 1987 Trans Am
Both worked when I parked the car a few years ago. My battery has died and doesn't take a good charge. It charges enough to start the car but dies within a couple of days. Could this be why my hatch and lights are not working now? Thanks for the help.
Old Feb 22, 2020 | 02:39 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: Firebird Rear Hatch and Headlights
it could be. it could be a lot of different things. one thing it is for sure is a pain in the ***. anything electrical is a pain in the *** when it doesn't werk. start with the fuses, follow the wiring from the termination point to the source of power, you should find the problem, but it's gonna be a pain in the ***.
Old Feb 22, 2020 | 06:22 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
First step in electrical diagnosis is you need to have a good battery. If the battery is not up to task, the results of any tests are suspect. Even a new, $50 Walmart battery is better than a questionable battery.
If you're going to leave the car parked, invest in some kind of battery maintainer. https://www.batteryminders.com/1510-...-with-warranty
Old Feb 22, 2020 | 06:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Headlights: Check that voltage is getting to the headlight control module in the engine bay (because it's super easy to access). Work the problem forward or backward from there.
Tail Lights: I'd check voltage at the Tail fuse first. Then pop the headlight switch out of the dash and check voltage at the terminals (might end up doing that anyway for the headlights). Work the problem forward or backwards from there. It's a pretty simple circuit. Tail fuse ---> light switch ---> wires to back of car ---> light bulbs.
Old Feb 23, 2020 | 04:21 AM
rgauder's Avatar
Car: 1987 Trans Am
It's not the tail lights, it's the rear power hatch.
Old Feb 23, 2020 | 01:32 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Something I made for myself a little while ago when I was wondering how it worked.
[img][/img]
[img][/img]
Old Feb 23, 2020 | 01:38 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
And another diagram I made for myself when I was trying to figure out why my headlight doors won't go up but always go down. Just ignore the green notes I added, it's the circuits that are of interest to you.
[img][/img]
[img][/img]
86_IROC_guy
Sep 5, 2008 02:43 PM
TBS84Camaro
Fabrication
Jun 14, 2004 12:38 PM
gmanuel
Dec 29, 2002 10:44 PM
