How hard is it to change the seat belt latch
Old Jan 13, 2002 | 09:09 PM
traxxxton's Avatar
When I was opening it the other day, the spring in the latch broke on my 87. How hard is it to do and what has to be done? Thanks.
Old Jan 13, 2002 | 10:44 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Mine did the same thing, i kind of messed with it and rigged it so it worked, but it was pure luck. Better go to a junkyard and get a new one, they're only attached with one torx bolt next to the seat.
Old Jan 14, 2002 | 12:50 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
if it has never been taken of before, the torx can be a b*tch to get off
Old Jan 14, 2002 | 01:05 PM
traxxxton's Avatar
It hasnt been off before, but it doesnt look too hard to do. I didnt know if the seat and everything had to come off too. Im going to see about picking up a new one from the dealer...eh better to get a new one insted of first looking around for a used one then hoping it will work. Thanks!
Old Jan 14, 2002 | 01:50 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
No the seat doesnent have to come out... just push it up all the way. I think its a t50 or t55 torx bit... f you have a problem breaking it loose, put a small pipe or what not on the ratchet for some extra leverage. Problem solved!
Old Jan 14, 2002 | 02:20 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
just don't strip the head when doing 88 WS6 TransAm GTA's idea.
then your in big dodo
Old Jan 14, 2002 | 03:06 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
Craftsman carries screw extractors, i got a set for christmas. but i don't know if they work on the torx screws or not.
but as john said, just be careful when you remove the screws.
robert
Old Jan 14, 2002 | 09:23 PM
traxxxton's Avatar
I went to the dealer tonight. They said it might be under that recall, but they will call tomarrow and find out. If it is, they said they will just replace the spring to make it work again. If its not still covered under that recall, they will sell me a whole unit for like $60, but all they have anymore is black so I dont know what I will do.
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
Navy8125
Aug 22, 2015 07:13 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
