Removing overspray from plastic
Old Aug 12, 2020 | 06:48 AM
theraymondguy's Avatar
I finally find a clean door sill seam cover, and it’s got overspray on it.
Looking for recommendations
Old Aug 12, 2020 | 09:50 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: Removing overspray from plastic
be very careful with this stuff, it is fragile, and even some mild solvents will permanently scar it. If there is paint on the back side, test a few mild cleaners starting with the mildest, like commercially available cleaners for interior plastics. when u don't know what KIND of paint has been oversprayed, it's hit an miss. you may need to sand it off and respray the parts, or have it done professionally, the sill portion is really difficult to do properly.
there are two colors that match the stock plastics very well, this one seems a better match for the re pops
..... and this one a closer match for the factory original gray panels. SEM also has all other interior matches for color.
Old Aug 12, 2020 | 11:07 AM
awesome, thank you. I’ve already went after it with fantastik and a diluted mixture of our degreaser, no luck. What about scotch Bright sos pads or steel wool?
Old Aug 12, 2020 | 01:58 PM
427seven's Avatar
those will definitely scratch, u probably have automotive paint on those, gonna be tough to remove. Always try a little on the inside of the part where it doesn't show, then u can see what it will do on the parts u can see.
Old Aug 12, 2020 | 02:02 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
You could use 1000 grit wet and dry sandpaper or finer and some water. that what I used and worked great. Takes a bit of time but will not damage the plastic.
Old Aug 13, 2020 | 12:48 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Brake fluid will do the trick. Let it sit on it for a bit and it will pull the paint off.
Old Aug 13, 2020 | 07:49 AM
82tarecaro's Avatar
Yup. I used it on plenty of plastic parts. Soak it a bit and it will come off. There is not much on there so it should clean up nicely.
Old Aug 13, 2020 | 08:20 AM
stron3's Avatar
Car: 87 Camaro Z28
After that a Magic Eraser (those white foam type pads primarily for kitchen use) should help remove whatever remains without scratching. Definitely stay away from solvents, they'll whiten the plastic super quick.
Old Aug 17, 2020 | 06:14 PM
Thank you all for your input. I tried the brake fluid trick and it worked as advertised.
GeneralDisorder
Interior Parts Wanted
Jul 18, 2019 06:33 PM
84 1LE
Aftermarket Product Review
Jan 17, 2016 02:04 AM
TallTim
Mar 4, 2013 07:31 PM
mantaguy
Feb 24, 2013 02:22 PM
camaro_5.7L_350
Jul 16, 2001 06:24 PM
