Stripe removal
Old Oct 16, 2020 | 04:42 PM
CJIROC's Avatar
Stripe removal
Looking to remove the stripe decals around my camaro. Any tips on the best method? Heat? Thanks.
Old Oct 16, 2020 | 07:50 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Stripe removal
Heat gun works pretty good, just be careful not to overheat the paint. 3M eraser wheel to get rid of the adhesive residue.
Old Oct 18, 2020 | 02:46 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
Re: Stripe removal
Heat, a razor and patience.
Old Oct 18, 2020 | 07:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Stripe removal
Old Oct 21, 2020 | 12:17 PM
sbetransam's Avatar
Car: 1986 Trans Am
Engine: 5.0L
Re: Stripe removal
This stuff is a BITCH to remove. I'm getting it slowly. I'm going to paint the car, so using a wire wheel on some of it, some stripper, 3m wheel, and then sanding. But how about the plastic bumpers? Any ideas? I don't want to use heat for obvious reasons.
Old Oct 21, 2020 | 12:40 PM
Car: '89 GTA
Engine: ZZ6TPI
Re: Stripe removal
You can use heat on the urethane bumpers. Just don't overdo it.
Old Oct 27, 2020 | 04:10 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Stripe removal
3m decal eraser wheel is what I have used on 90's Toyota trucks but haven't used it on the thridgen decals. On factory paint if you keep it clean it doesn't scratch the paint. Some of the softer enamels (Maaco etc) would probably not hold up as well. Also if factory paint acetone can work well just make sure the paint tolerates it.
if you are planning on doing a paint job after you can get more aggressive with the chemicals just make sure you get all the residue out of the crevices before painting.
dale3in98
Exterior Parts Wanted
Aug 24, 2016 04:08 PM
warren23
Mar 25, 2011 02:19 PM
Camaro355Z28
May 20, 2007 06:20 PM
smithtc
Jul 1, 2004 09:04 PM
