Vert - Creaking knocking sound at low speeds - help me find it!
Old Oct 20, 2020 | 10:21 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
That other forum is sleepy.
https://www.thirdgen.org/forums/susp...d-help-me.html
Old Oct 23, 2020 | 09:51 AM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
Re: Vert - Creaking knocking sound at low speeds - help me find it!
creaking sound- welcome to convertible life
knocking sound- not sure about that one
Old Oct 24, 2020 | 08:07 AM
Engine: 350 TPI L98
Transmission: WC T5
Thanks. Mmmm. If I had to pick one I would go knock. Maybe I need to repost. :-). I do have some creaks. Those are clear.
Old Oct 24, 2020 | 05:30 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Start tapping with your fist (not too hard on plastic parts) in/around the area you feel its coming from. That's how i've pin pointed creaks/squeaks 99% of the time.Of which i have nearly zero of.
Old Nov 10, 2020 | 02:04 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Does it sound like its coming from inside the cabin or out ? Try go with a wrench and sockets and just tightening stuff, or check the door pins. I found mine on my truck were loose, and found a few loose bolts as well!
Old Nov 10, 2020 | 11:35 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Bushings? Sway bar links?
mine was making noises and that’s what it was...
Old Nov 13, 2020 | 04:39 PM
Engine: 350 TPI L98
Transmission: WC T5
Did all that. Sounds like it might be under the dash and/or at the firewall. Tightened everything, went for another round of welding. When the car was cold this morning it didn't do it until it warmed up a little.
ThePain
Convertibles
19
Jul 14, 2020 10:18 AM
90IRAWKZ
Convertibles
Dec 25, 2014 01:59 AM
Darkshot
Northern California
Jan 28, 2008 05:12 PM
85transamdriver
Nov 20, 2005 05:50 PM
