Replacing hood hinge on Formula
Old Oct 27, 2020 | 04:08 PM
Ct1987's Avatar
Has anyone replaced the hood hinges without taking the hood off. Back in the day, I was able to remove Thunderbird hinges by supporting the hood from the ceiling of the garage.
The reason I want to change them is that the bottom strut studs on both sides are coming apart. I don't see a nut behind them to tighten so I assume they are swedged.
Louis
Old Oct 29, 2020 | 11:30 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Replacing hood hinge on Formula
You can replace them one at a time with the hood open. Just need a helper to hold the hood for you while you swap the hinge.
Old Oct 29, 2020 | 11:42 AM
Ct1987's Avatar
Thanks TransAm
Louis
Old Oct 30, 2020 | 07:57 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Louis
What are the "bottom strut studs"?
You can prolly hold it up, Its just replacing the hinge (I did it) while supporting the hood so it doesn't fall and damage anything. Its easier with a bunch of friends helping though in case things go wrong...that hood can get pretty heavy!
Bigscott
Mar 28, 2021 09:27 PM
JonM
May 9, 2014 04:42 PM
Mr300
Sep 2, 2002 10:56 AM
