Adjusting windows
Old Nov 9, 2020 | 12:13 PM
1badcj8's Avatar
Car: 89 Iroc Z G92
Engine: 5.7 HO
Axle/Gears: 3.43
Adjusting windows
Recently I rebuild my doors with new pins cam rollers etc... While at it I added power window kits and new rubber on the driver's side top and bottom and bottom on the passenger side.
Well, now I've got a brutal wind noise on the driver's side. When I close the door I can see on the outside it doesn't seal like it should, along the top and front, Unless I close it pushing (only) at the very rear top corner of the window then it seals fine.
With me inside I've had my wife close it for me and take a ride, no wind noise.
SO has anyone adjusted the window to roll up tighter?
Old Nov 9, 2020 | 02:05 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Adjusting windows
It can be done, here is a link to the how-to section that has a write up on it. If you don't like that one there are a ton of other threads if you search around.
https://www.thirdgen.org/windowadjust/
Old Nov 9, 2020 | 04:24 PM
1badcj8's Avatar
Car: 89 Iroc Z G92
Engine: 5.7 HO
Axle/Gears: 3.43
Hey thanks man, I will check that out. I did look a fare amount but found lots that were pretty pretty old and not specific.
Old Nov 9, 2020 | 04:55 PM
Engine: 5.7 L98
You got it, there is some pretty good info in that how to section that I have used before. A factory service manual is also really handy with these cars.
Let us know how you make out with that adjustment.
chevydrvr
Feb 24, 2012 05:07 AM
Lashier
Nov 20, 2009 01:15 PM
bryanlz
Dec 10, 2008 06:00 PM
Thunderboy
Apr 16, 2004 05:41 PM
92 zzz28
Jan 15, 2003 10:00 PM
