Leak from both windows
Old Nov 21, 2020 | 03:57 PM
LestatB's Avatar
The plastic triangle at the front of both windows leaks will replacing the weather stripping fix it?
Old Nov 21, 2020 | 10:11 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Leak from both windows
Pretty easy to change without taking the door apart, 1A auto has a video. Not that expensive either.
https://www.1aauto.com/how-to-instal....com/video/861
The question is whether it’s the cause. Does the window fit nice and snug? What kind of shape is the weatherstrip in? I had a pretty good air leak from the driver side triangle, replacing it cured it.
Old Nov 21, 2020 | 10:28 PM
LestatB's Avatar
Thank your very much because there is a air leak from the drivers side triangle
Old Nov 21, 2020 | 10:35 PM
LestatB's Avatar
thank you
Engine: 5.7 L98
That will likely cure what ails it then. Check rock auto and 1A they both have the part, I would get the pair and just change out both sides. Use a little black permatex adhesive to seal it on the top, also a little Dawn dish soap and water on the part that slides in the door will ease installation a lot and help bottom it out for best fit.
Old Nov 21, 2020 | 10:48 PM
Engine: 5.7 L98
If that doesn’t cure it, the how to section on here has an article on how to adjust the windows. I haven’t adjusted them before but I have a feeling new weatherstrip will cure your issue.
Old Nov 22, 2020 | 11:57 AM
LestatB's Avatar
Thank you I really appreciatethe help
rodrigo diaz
Aug 8, 2006 08:52 PM
Maverick_82
Nov 3, 2004 03:56 PM
The Judge
Feb 25, 2003 08:40 PM
ThirdgenCam
Apr 16, 2002 12:46 AM
92blue
Feb 23, 2002 06:35 PM
