** Iroc Front Bumper Assembly
Old Dec 22, 2020 | 07:59 AM
cwb90's Avatar
Is there any special sequence to assemble the front nose and lower chin spoiler? Does any of the black plastic under the nose / radiator area have to be installed first or can I just go ahead bolt up the front nose first? Do headlights or fog lamps need to be installed first? I have an assembly manual for a 86 but its pretty vague, Thanks for any help.
Old Dec 22, 2020 | 08:20 PM
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Axle/Gears: MOSER 9"
Re: ** Iroc Front Bumper Assembly
Some times you have to look at everything that has to go back on and decide on a sequence that will let you get to all the fasteners. Without knowing what parts you are talking about makes it impossible to say. However, You can put most things on with the nose on the car, but I find it easier to get as much mounted as is practical before the nose goes on. Headlights and trim rings for example. Sometimes you have to try until you get a process that works for you. Don't be afraid to get it wrong, Because you will remember it the next time.
File Type: docx
zemon1
Mar 22, 2009 07:07 PM
86_IROC_guy
Sep 9, 2008 03:24 PM
88KARRV6
Feb 17, 2007 12:45 PM
