Pics of lower mounting point of fender
Old Jan 5, 2021 | 07:07 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Does anyone have a good GM fender to take pictures of?
My fenders are in good shape, but the lower mounting points are messed up.
The attachment points are gone on the car as well.
Plan of attach is, recreate the attachment points as best I can. One of them is on there, just bent out of the way so I should be able to get a good rebuild of the tab from that.
Then hang the fender and see where that attachment point sorta lays, then fabricate a new attachment point on the car to receive it.
Repeat on opposite side. Any help would be greatly appreciated. Thanks!
Old Jan 5, 2021 | 08:02 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Pics of lower mounting point of fender
Which year? 91/92? The mounts were slightly different those years for the new style ground FX. I believe the locations were slotted vs a hole.
Old Jan 5, 2021 | 09:24 AM
Engine: LS3
The car is a 1991 Z28. Fenders don't have mounts and the car doesn't either. I need to fabricate it all from scratch but making it look as close to OEM as my skills can would be nice.
Pics of fenders from a 91/92 would be ideal. But if it is just a hole vs slot change, no big deal. I can adjust as I fab.
Old Jan 7, 2021 | 07:19 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Hopefully this helps, and they are not the best pictures. The fender in primer is a 91/92 and the bent fender in red is 1990.
1990 rear
1990 Front
91/92 Front
91/92 Rear
Old Jan 7, 2021 | 08:18 AM
Engine: LS3
PERFECT!
Thanks you very very much. I will reference these images as I correct my fenders.
I will post pics in my build thread when I get to it.
Thanks again!
DBLTKE
Jul 29, 2025 04:27 PM
F-body driver
Nov 17, 2016 10:24 AM
lasher_350
Nov 18, 2002 12:29 PM
