Door removal
Old May 23, 2021 | 03:42 PM
KPosey's Avatar
Car: 1989 Iroc
Transmission: 5spd
Axle/Gears: 3.45
Door removal
Hello, I am hoping someone can help me out. I need to swap doors on my 1989 IROC. What is the best way to pull them and what pitfalls do I need to avoid? Thanks in advance. From what I see it looks like I will have to remove the front fender to gain access to the bolts
Old May 23, 2021 | 09:53 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Re: Door removal
I highly suggest a good jack that can accept a door:
https://www.eastwood.com/e-z-rest-door-hanger.html
I got this one form Eastwood a couple years ago, It was perfect to remove and also reinstall the door. I did it by myself off and on, on both sides. Made it very easy to align the doors too. It adapts to a standard car jack. I used one from Harbor Freight.
Yes removing the fender makes it easy to take off as well as align the replacement door.
Old May 24, 2021 | 10:44 AM
Abubaca's Avatar
Re: Door removal
You can remove the inner wheel well plastic liner and get access to the bolts. MUCH easier than removing the fender.
Old May 24, 2021 | 08:08 PM
Engine: 5.7
Axle/Gears: Stock
Re: Door removal
True. but aligning it can be tricky. I found putting mine back on with the fenders off and that jack tool made it very easy for a 1 man show. I did it all myself and could not be happier with the results. Those doors are VERY HEAVY.
Old May 25, 2021 | 01:53 PM
Abubaca's Avatar
Re: Door removal
Totally agree with the jack! ....couldn't see doing it without some kind of jack. ...as for aligning....yeah....I agree. I used a second set of hands. By yourself, with the fender on, it'd be tricky.
KPosey
May 23, 2021 10:35 AM
87 Camaro Dude
Jan 2, 2013 02:30 PM
TekViper
Mar 6, 2003 08:54 PM
Brian Felts
Jan 23, 2003 10:55 PM
87 iroc L98
Dec 18, 2001 08:44 AM
