Wipers very slow - seized linkage?
Old May 23, 2021 | 04:11 PM
sklearman's Avatar
Car: 1990 Trans AM GTA 1 of 78
Engine: 5.0L FI
Transmission: 5 spd manual. Rare.
Looking for any experience here! I have a 1990 TA GTA. The wipers work, but are extremely slow to move up and down. I suspect the linkage is seizing up and corroded. I'm not sure (yet) how to remove the entire linkage and break it down to re-lubricate the linkage points. But, is it possible to accomplish this in place with penetrating oil? I can't find any videos on how to access, remove, and repair the wiper linkage, and the Chilton's manual diagrams are useless. Also, the Chilton manual shows a couple of specialized tools.....are those something I need to get?
Old May 23, 2021 | 04:31 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Wipers very slow - seized linkage?
Not all that hard to get to. Just take off that screen in front of the windshield and you'll be able to see it all. Shouldn't require any special tools.
Have fun!
Old May 23, 2021 | 04:43 PM
sklearman's Avatar
Engine: 5.0L FI
Thank you! I'm hoping to not have to remove (or replace) the entire assembly.
Old May 27, 2021 | 12:15 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I have a similar issue with my wipers, I've confirmed that my linkage is not binding or seized. In my research to remedy the issue I found that there are 6 different part numbers for the control board on the wiper motor for 1989 alone. It's possible the control board could be your issue.
Old May 28, 2021 | 03:42 PM
sklearman's Avatar
Engine: 5.0L FI
That could be too. When I started looking into the issue, a lot popped up about the linkage seizing up which makes sense. I'd like to check that first before getting a new wiper motor/computer but trying to get to the linkage assembly is proving difficult. I tried removing that plastic mesh but couldn't make it so. Then of course, I have no idea if you can lube the linkages in place, or if the mechanism has to be removed. Nothing in the Chilton book either.
Old May 28, 2021 | 04:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You could always try spraying some kind of penetrant like PB blaster or something into the joints with a straw and then after a bit repeat spraying with the wipers on. Can't hurt but may make a difference
Old May 28, 2021 | 04:31 PM
sklearman's Avatar
Engine: 5.0L FI
That's what I hope to do. The problem is accessing the linkages.
Old May 28, 2021 | 07:09 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
What' the problem removing the plastic mesh thing? Step one, raise hood. There's one small bolt/screw in the middle by the windshield to undo then I believe one plastic serrated pin on the driver side pushed down into a hole and two on the passenger side. You'll see to flat plastic spots and if you feel under the inside above the mesh you'll feel the pins on that side. Pry them gently up and out from around the outside edges ,and you'll still need to be careful with the washer hoses so take it easy. There may be more pins holding it on but just stick a good sized flat blade screwdriver under them and they should come out very easily with little effort
yours may be more brittle than mine so be gentle
Have fun
Old May 28, 2021 | 08:01 PM
sklearman's Avatar
Engine: 5.0L FI
Have fun
Thank you for the info. That helps take the guesswork out of it.
CrystalCamaro
Apr 9, 2014 01:04 PM
BustaZz
Jan 9, 2009 07:39 PM
1985 BANDIT III
Mar 6, 2008 08:49 PM
JeffD
Feb 19, 2006 08:29 PM
