Swapping ground effects from 91-92 Camaro to 1988 Camaro
Old Jun 11, 2021 | 02:13 PM
isaac911's Avatar
Can the 1991-1992 Ground effects just be bolted onto the 1986-1990 Camaros? I'm not looking to change the door or the rear ground effects just the front and side spoilers.
I'm sure the question has already been asked but i cannot find anything in the forums.
Old Jul 9, 2021 | 02:33 AM
Tonyrodz's Avatar
Transmission: auto
Re: Swapping ground effects from 91-92 Camaro to 1988 Camaro
The front side of pieces should bolt on with no issues. Make sure you get the mounting brackets for the 91-92 nose, as it might be a little different. Also grab the lower dam pieces that go under the nose. They help to direct air to the radiator so you don't overheat.
ted gerlach
Exterior Parts for Sale
Jan 7, 2009 05:55 PM
Don_89Iroc
Jan 12, 2002 11:05 PM
