Need Upper Door Trim
Old Sep 19, 2021 | 10:16 PM
Fxd99harley's Avatar
Car: 1984 Trans Am
Upper Molded plastic door trim for both doors needed. This is what inner door panels attach to. The plastic Tabs that have attaching nuts are broken off. Trying to think of a decent way to form some '****' since this is all that's wrong. Any help appreciated.
Attached Thumbnails Need Upper Door Trim-16321075502747605961953401458137.jpg
Old Sep 20, 2021 | 11:51 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Need Upper Door Trim
One "fix" that you'll never see after it's installed is to just use aluminum duct tape to hold the rail on to the back side of the cardboard before it's installed. Should hold the rail on the cardboard fine as long as you're careful handling it before the install. Once the door panel is back on the car, the top rail will clip to the door itself, and the trim panel clips will hold the cardboard on. Only thing that sucks is it's not a permanent fix -- you'll have to redo it every time the door panel is taken off.
I'd consider new door panel assemblies if they were closer to the originals, but they're not even close for my cars.
Old Sep 20, 2021 | 01:07 PM
Car: 1984 Trans Am
Thanks for the information. I have new Panels and was hoping I could do a permanent fix but whatever works....lol
zride91
Aug 13, 2009 12:06 PM
transamice
Interior Parts Wanted
Feb 23, 2009 04:56 PM
Ray102386
FAQ Board
Mar 28, 2006 02:45 AM
Kevin84Z28
Oct 26, 2004 10:25 AM
MileHighDiesel
Jan 8, 2003 03:20 PM
