Shooting single stage metallic
Old Sep 24, 2021 | 11:48 AM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I ended up with quite a bit of orange peel on my car when I painted it with a single stage metallic. Now, I know you can't color sand a metallic single stage. So I plan to retry and go at it again. it was four parts paint, one part reducer, and one part activator. For the most part, there was not really any tiger stripping, but just some orange peel. It was shot out of a 1.5mm ingersoll rand gun. I plan to buy a new gun that has a 1.3mm tip to shoot it with. Any advice?
Old Sep 24, 2021 | 04:35 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Re: Shooting single stage metallic
The correct reducer for the actual temps or a slightly slower reducer since you are doing a complete refinish, a little slower gun speed, bump up the pressure...(check your pressure at the cap). You're going to have to sand the car flat first. If you're happy with the body work, and aren't priming/sealing anything...I would wetsand the entire car with 1200 or 1500g to cut the orange peel, then finish with 2000g. Prep and spray.
You're using the same paint? What brand? What line? Check the MFR pages to see that there isn't a re-coatability issue.
Not sure why you'd want a single stage. Depending on your material/brand...you can still clear it, if you have the funds. (More durability/protection. Easier to take care of. Better holdout and gloss)
Logan Bryant
Jul 14, 2021 09:01 PM
OS3Fleming
Nov 16, 2011 03:48 PM
Spike_Akers
Oct 3, 2010 09:42 AM
blackblazer717
Sep 2, 2008 03:45 PM
1989karr
Jun 27, 2005 06:35 PM
