fender fit?
Old Jan 6, 2022 | 03:57 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
fender fit?
i want to install the trans am vented fenders on my 91 base model firebird. are all the thirdgen front fenders interchagable? i know the nose pieces are different but the fenders appear to be identicle.
Old Jan 6, 2022 | 04:03 PM
Evilokc's Avatar
Engine: tbi 305
Re: fender fit?
search feature actually worked for me. looks like 85-92 will fit with only ground fx mounting holes needing to be drilled in some cases.
Old Jan 19, 2022 | 03:29 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
Re: fender fit?
They’re all the same from ‘82-‘92. The Trans Am fenders had the opening cut out with stamped out flange holes inside for the decorative vent cover to attach. So, after you cut out the hole for the vent, you will have to come up with a way to attach the decorative vent cover to the fender.
The best solution would be to source some ‘82-‘84 Trans Am fenders from a wrecking yard or parts place. Those had the vents with no GFX holes (except the ‘83 Daytona 500, aero package equipped ‘84 T/A and the 15th Anniv cars). Or, you can possibly try Classic Industries which I think sells aftermarket T/A fenders.
kevins_84_bird
Apr 12, 2009 06:23 PM
kobrak
Jun 21, 2008 07:15 PM
gray89vert
Oct 24, 2006 04:53 PM
87pontiac
Aug 11, 2006 09:58 AM
IROCET
Sep 25, 2004 12:42 PM
