Front Clip swap
Old Jan 10, 2022 | 12:05 AM
Pattyko's Avatar
Car: 86 Z-28
Engine: 305 for now
Front Clip swap
Can I take the complete front clip (including the hood) from an 1992 Z28 and put in on a 1985 Z28? TIA
Old Jan 15, 2022 | 01:49 PM
vf750rider's Avatar
Car: 1992 Teal RS
Engine: 350 Carbed
Axle/Gears: 4th Gen Rear 3.42
Re: Front Clip swap
On fitment - I'm not 100% sure but I assume that it should fit and bolt on the same.
On looks - there are differences. 2 major differences that come to mind are ...
92 has a chin spoiler that I don't think earlier cars had. And that chin spoiler will have the "ground effects" just in front of each front wheel - you'll be missing the matching "ground effect" side skirts under the doors (unless you can get them from a 91/92 car also).
92 Z28 hood should have blister dimples and blisters (same general shape as the earlier louvers on hoods) that was only present in 91 and 92. I'm no expert on what years had the louver hoods either - maybe your 85 has louvers? And I don't know if louvers and blisters are interchangeable ... so you may or may not be able to keep (if you have) louvers and put on the 91 blister hood.
Old Jan 15, 2022 | 03:53 PM
Pattyko's Avatar
Car: 86 Z-28
Engine: 305 for now
Re: Front Clip swap
Thank you @vf750rider for the info.
Old Jan 15, 2022 | 06:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Front Clip swap
Blisters and louvers interchange, both hoods are the same.
silent420wolf
Oct 27, 2014 05:55 PM
toxzzic1
South East Region
Jan 25, 2013 06:13 PM
Angelduran5858
Mar 12, 2012 06:46 PM
