T top seals leaking in rear?
Old Feb 12, 2022 | 06:37 PM
NickSpill's Avatar
Car: 1982 Camaro
Transmission: 2004r
I put in new t top seals to try and fix some leaks but now I am getting a leak on the roof about 4 inches behind the t tops at a seam. I can not seem to find where the water is getting in. I have adjusted the t tops as low as they can go and it still leaks. I have the headliner removed so I can see where it is leaking but it’s at a seam so I cannot see in. When I run water on it it takes a minuet for the water to get in so I can’t pinpoint the spot it is getting in. Im honestly lost as to where the water can be getting in and am almost at the point as to converting it to a hard too even though I really would prefer to have the t tops. Any suggestions would be greatly appreciated.
Old Feb 13, 2022 | 07:53 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: T top seals leaking in rear?
Did you put in the 3M rope caulk "bridge" between the ttop section and the vertical B pillar section?
Or, if the leak is coming from somewhere around the center of the car, did you seal the areas shown here?
modocwex
Aug 20, 2014 10:13 PM
gon8go
Aug 31, 2006 11:38 AM
Paul Riccioli Jr
Feb 23, 2003 12:31 AM
TransAm383
Jun 28, 2001 08:51 PM
Hummer
Apr 24, 2001 05:53 PM
