IROC extractor hood
Old Apr 24, 2022 | 08:11 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
IROC extractor hood
I wanted something extraordinary and unique for my build, so I came up with this.
Bead rolled and shirking the pans
Added extensions to the sides
Fitting and preparing for welding
After about 12 hours of tig welding
It is now ready for primer and block sanding
Old Apr 24, 2022 | 08:21 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: IROC extractor hood
woah
Old Apr 24, 2022 | 08:50 PM
skinny z's Avatar
Things that make you go hmmm.
I like the idea.
Do you have a cold air intake package as well?
Old Apr 24, 2022 | 09:12 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I dig it. Any plans for ducting behind the radiator?
Old Apr 24, 2022 | 09:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
How in the world do you have room for that? My engine gets closer to hood the further forward in engine bay. It even bumps the hood insulation just behind the radiator.
Old Apr 24, 2022 | 10:16 PM
Swapper's Avatar
hmm i never thought about that. i like the idea. i did mine a little different
Old Apr 24, 2022 | 11:42 PM
soloc4's Avatar
I like the idea.
Yes, it’s the aluminum box in the RH battery tray.
Not at this time, if it were a dedicated track car I would think about it. The ducts align with the dual fans though.
It’s a Camaro, if it were a Firebird then this would not work. It would look out of place on a Trans Am anyway. The ducts curve down over the cowl brace and the intake tube in the picture.
Old Apr 24, 2022 | 11:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yeah, Camaro has the goods in the hood clearance department for sure.
Your engine bay looks so clean and tidy, man! Your fabrication work is always sooooo nice, too!
Old Apr 25, 2022 | 12:43 AM
soloc4's Avatar
Thanks, I like to push my limits. This one went way beyond those. I learned a lot with this project. You would think that at my age, I would sit back and retire, but I’m just not ready for that yet.
Old Apr 25, 2022 | 03:03 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Clean!!
What radiator top support are you using? that looks kinda like a third gen one but at the same time looks different?
Old Apr 25, 2022 | 03:29 PM
soloc4's Avatar
Originally Posted by 1989karr
Clean!!
The one in this picture is the original from the '84. I have since installed a Griffen radiator and had to make a custom aluminum piece that looks very similar to the stock one.
Old Apr 26, 2022 | 01:27 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Ahhh nice!
84, no wonder it looks different than the ones Im more used too.
Great build!!!
Old Apr 27, 2022 | 06:39 PM
soloc4's Avatar
A successful test fit, it’s as if it was made for the car.
I’m very happy with how well it fits
Old May 3, 2022 | 07:26 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
So those extractors are falling inside the "triangle" of the strut tower brace with the hood closed?
Old May 5, 2022 | 05:05 AM
soloc4's Avatar
No, they are forward of the brace. There is a 3 1/2" gap between the forward edge of the intake tube and the aft edge of the radiator shroud and this is where the duct openings are. They also happen to align with the cooling fans. on the radiator. I should take a picture of this with the hood closed to illustrate it.
Old May 11, 2022 | 06:15 PM
DynoDave43's Avatar
That makes more sense. It was just hard to visualize. With the radiator hose/pipe running through, I was having a hard time imagining it clearing.
Old Oct 9, 2022 | 09:27 PM
soloc4's Avatar
I’ve gotten a few things in epoxy primer
Old Oct 11, 2022 | 11:20 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Have you thought about putting those IROC louvers that are cut out over top? Give it a factory look but some real function.
Old Oct 11, 2022 | 05:11 PM
soloc4's Avatar
No! I could have put TrackSpec grills on this like everyone else has done and it would have been a lot easier. As far as opening up the IROC inserts, it’s been done by a good friend of mine and we will be side by side at some shows in the future.
BajaDaze IROC hood
I have made matching grill inserts for the front bumper and the hood to complete the look.
Matching stainless steel grills
The final product will be unique look for a one of a kind build.
Old Oct 12, 2022 | 06:05 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Looking fantastic!
A++
Old Oct 12, 2022 | 11:31 PM
1965gp's Avatar
This is really a fantastic take on the Iroc hood
Old Apr 5, 2023 | 07:10 PM
soloc4's Avatar
Final update to this thread. The grills have been installed and the hood is ready to be installed on the car.
Old Apr 5, 2023 | 07:26 PM
skinny z's Avatar
Well thought out.
Well executed.
I'd be keen to see something with the hood up. It's been a while.
What's the cold air intake comprised of again? Reminds me of some Corvette details I saw years back with the CAI over the rad (not unlike the TPI setup) and the hood designed to allow the radiator to vent through the cut outs in the hood. Much like your design. (I apologize if I covering old ground).
EDIT: I see your CAI looks to be off to one side. Is that correct?
Old Apr 6, 2023 | 10:22 PM
soloc4's Avatar
Well thought out.
Well executed.
Yes, the CAI is on the right side battery tray. The air comes in from the enlarged side opening. The ABS system is in the left side battery tray, so I went with a single 4” intake tube. The inspiration for the hood came from the GT40, but not intended to be a full race aero. The ZL1 hood is not fully ducted and it provides additional downforce at high speeds, but I’m not sure that will ever be tested on this car.
Old Apr 12, 2023 | 10:35 PM
soloc4's Avatar
Here is a POV of the grills from the drivers seat.
Old Aug 4, 2023 | 10:32 AM
soloc4's Avatar
A couple of pictures with the hood on the car
Old Aug 10, 2023 | 06:14 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Fantastic!
Old Jul 17, 2024 | 11:17 AM
bluehog67's Avatar
Car: RS
Transmission: 5 speed
Great job. These turned out phenominal.
Psycho_91Camaro
Fabrication
123
Aug 6, 2012 07:42 PM
WickedCrazy
Fabrication
Mar 15, 2012 01:02 AM
INTIMIDATOR Z
Members Camaros
Aug 31, 2011 01:05 PM
Grifter757
Members Camaros
30
Jan 29, 2008 04:56 PM
Demon Z28
Pacific Northwest Region
Jul 3, 2001 07:52 AM
