Cap over trans tunnel to convert to Auto trans
Car: '89 Firebird
Engine: 7.0L
Starting to plan out a conversion from manual trans to auto trans. Anybody know of a cap I can place over the tunnel that will give me the geometry needed for auto shifter and cable pass-thru? I don't want to cut out my stock trans tunnel, prefer to have a cap I can place on top that will give me the features needed to mount auto shifter. I'd like to leave the option of going back to manual if I want.
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Re: Cap over trans tunnel to convert to Auto trans
A simple sheet metal cover to replace the rubber boot that bolts on over the manual stick. You could use the boot as a template for size and shape. If you want to get fancy, you could bead roll it to prevent oil canning.
Axle/Gears: 10 Bolt 2.73 Open
RS91
Jul 29, 2001 10:23 PM
