Tough to install t-top weatherstriping?
Old Jan 20, 2002 | 04:54 PM
mckenzie's Avatar
Hello, how tough is it to install t-top weatherstriping? any great hints, and where is the best place to buy? thanks, tom
Old Jan 20, 2002 | 06:34 PM
Blue502's Avatar
No, but you need to make sure you get adhesive all the way along, no gaps. Also while you have your weatherstripping out, check very carefully for any pinholes in your sheetmetal. If you find any, get them welded up first, and then paint the channel with POR15 or something. Got mine from the dealer in '99
Old Jan 20, 2002 | 07:18 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
A local guy changed his T-top weatherstriping and he said that it leaks more now than it did before. Is this true, or did he just not seal it correctly? I planned on getting new weatherstriping on my Firebird when I get it painted, but if the leaking will only get worse, than I may change my mind. Thanks.
Old Jan 20, 2002 | 07:26 PM
Blue502's Avatar
He either didn't install the weatherstripping correctly, or else his tops need re-adjusted. You should re-adjust them afterwards anyway. Mine don't leak a drop.
Old Jan 20, 2002 | 08:21 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Mine don't leak either. But If I remember right it takes about 4 of those tubes of sealer to do the job. And you have to move rather quickly. The instructions that came with mine said to fill both the inner and outer chanels with sealer. Better put some masking tape on the painted surfaces, the sealer will squish out, and could get on the paint.
Old Jan 21, 2002 | 12:36 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
mine leaked, until I filled the center strip with Silicone, now I can drive thru a lake and it would not leak... not a drop.
Actually the replacement t-top seals are FAR superior to the originals... in my opinion
John
Old Jan 21, 2002 | 06:16 PM
mckenzie's Avatar
Well, where did you all get your gaskets from? dealership or aftermarket company? thanks, tom
Old Jan 22, 2002 | 07:23 AM
okfoz's Avatar
opps...silly me... I fortot to tell you that...
I bought a whole kit from Classic Industires. It also fixes the rippley rubber on your T-tops, looks mucho better...
John
Old Jan 22, 2002 | 07:42 PM
mckenzie's Avatar
Hey, is the "rippley rubber" the strip that goes on the t-top itself where the top of the window hits? thanks tom
Old Jan 22, 2002 | 07:55 PM
Blue502's Avatar
Its the one on the t-top that covers the one that the window hits.
Old Jan 22, 2002 | 08:08 PM
mckenzie's Avatar
sounds great! thanks, tom
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
t-top89
Aug 21, 2015 09:52 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
