Patch repair
Old Nov 17, 2022 | 07:44 PM
AnubisZ28's Avatar
Patch repair
Hi 3rd gen lovers, I'm needing patch panels for the inner rear wheel and can't seem to find any. Only thing I can find is 67/69 repair and look PRETTY DAMN CLOSE but I wasn't to sure if they would work. Plus what is the panel that is in between quarter and trunk. Pics will be attached.
Old Nov 19, 2022 | 07:57 PM
LosingNirvana's Avatar
Car: 1983 Z28
Engine: Carb LG4 :(
Transmission: NWC T5
Axle/Gears: 9 bolt 3.27 posi
Re: Patch repair
Have to get one from the junk yard. If you cut it out larger than you need you can section the wheel house and trunk drop off too.
Old Nov 21, 2022 | 04:43 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Patch repair
New sheetmetal for the rear inner or outer wheelhouses are not available. Your options are cut it out of a rust free donor, or cut out the bad sections of yours and fabricate patch panels and weld them in.
RyanZ
Feb 16, 2010 04:50 AM
brooks5453
Feb 8, 2009 08:31 PM
TKO500
Nov 7, 2005 10:05 PM
formula761
Aug 17, 2003 01:07 AM
88firebird305
Oct 6, 2001 01:33 AM
