door help
Old Mar 24, 2023 | 02:40 PM
blacksuede's Avatar
Car: 1990 camaro rs
Engine: White Performance 383
Transmission: PerformaBuilt 700r4
Axle/Gears: strange 12 bolt 3.73
door help
i have no idea what these pieces are called running down both doors, im assuming its a bump guard. i just need to know if there glued on? id like to get rid of them
Old Mar 24, 2023 | 03:21 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: door help
Yea, door guards. They're held on with basically 2 sided tape.
To remove just heat with a hair dryer and gently pull off, then use WD-40 and a rag to remove the remaining sticky.
Old Mar 24, 2023 | 08:45 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: door help
And the paint underneath will likely look brand new and shiny, and unfaded (red tend to fade with age).
Old Mar 24, 2023 | 10:31 PM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Re: door help
As mentioned above I used a hairdryer/heatgun and fishing line as a “saw” to get through the glue behind the trim peice. Mine took considerably more effort than I anticipated. Be careful not to damage paint if it’s nice!
Old Mar 25, 2023 | 04:09 AM
blacksuede's Avatar
Car: 1990 camaro rs
Re: door help
I'm actually preparing to paint it a candy apple red. I've got it in my head this car would look way better without them. I appreciate the info I'm getting.
Old Mar 25, 2023 | 05:27 PM
DynoDave43's Avatar
Re: door help
I hope you'll post some progress pics. That's a color I love on just about anything.
Old Mar 25, 2023 | 05:30 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: door help
I took took them off years ago w fishing line and used a 3m eraser wheel to take the adhesive off. It works great and is totally safe on paint.
Old Mar 26, 2023 | 01:12 PM
danoko's Avatar
Axle/Gears: 4.11 Ford 9"
Re: door help
I used dental floss instead of fishing line. I also used it to remove emblems off of other cars.
Old Mar 26, 2023 | 03:52 PM
blacksuede's Avatar
Car: 1990 camaro rs
Re: door help
I went out today and used fishing line. turns out 33 year old glue isn't very strong. It did take some paint with it but sense its going to be painted in the next few weeks, I wasn't worried. My car is known to be cursed, anything that can go wrong will go wrong so im surprised it was that easy.
kitt23
Mar 9, 2013 10:22 AM
CamaroSpeed
Dec 8, 2007 11:22 AM
joekickass
Jun 22, 2004 02:41 PM
David Culpepper
Aug 3, 2001 02:54 PM
