Weather stripping
Old Dec 8, 2023 | 08:39 AM
Shaunejulian's Avatar
Car: 1986 Blue Iroc Z TTop
Engine: 305 LG4
Transmission: 5speed
Weather stripping
Is it still possible to buy GM weather stripping for ttops and doors? I ordered door seals from hawks but after doing some reading I'm aftraid they won't fit right. I do not need ttop seals but my roof rail seal is leaking that does down the window. I thought about replacing the whole ttop seal since it is part of the roof rail seal. Just wondering if I could still find GM so I don't have to go aftermarket to make sure they fit correct.
Old Dec 8, 2023 | 09:53 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Weather stripping
Only if you can find NOS.
Old Dec 8, 2023 | 09:59 AM
Engine: 305 LG4
any suggestions on a good place to get aftermarket ones?
Old Dec 8, 2023 | 10:02 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Hawks has a couple options.
Old Dec 8, 2023 | 12:11 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
I used the Steele Rubber kit on my hardtop and was very happy with them.
Old Dec 8, 2023 | 11:17 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Where did you get those and do you have part numbers by chance?
Old Dec 9, 2023 | 07:42 AM
soloc4's Avatar
Their online catalog. The website breaks it down to year, make, and model. They sell everything as a kit or individual seals that you may need. They even have the door glass front corner seals.
Old Dec 11, 2023 | 06:40 PM
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Pretty big topic of debate, since no one seems to make them as good as factory. I have Fairchild and am pleased with them. I also hear good things about Steele. Avoid OER weatherstrips like the plague.
Old Dec 11, 2023 | 06:48 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Is your door weatherstrip Fairchild?...
Old Dec 13, 2023 | 06:05 PM
KITT87's Avatar
Engine: 2.8 V6
Yeah, specifically the window/roof rail one. I’m gonna pick up the lower door ones soon (hopefully) since apparently Fairchild is one of the few brands that has the plastic inserts.
Old Dec 13, 2023 | 06:07 PM
KITT87's Avatar
Engine: 2.8 V6
just realized I should’ve clarified, I have a hardtop. Not sure if Fairchild’s T-top set is any good, but in my experience the brand isn’t just dumping out trash.
Spartan13
Sep 16, 2023 02:09 PM
86WS6
Apr 14, 2021 08:28 PM
linkz761
Nov 11, 2009 06:49 PM
iansmusical
May 5, 2008 02:48 PM
Abubaca
Dec 15, 2002 09:00 PM
