Floor Pan to Console Patch - Butt Weld or Lap Weld
Old Feb 4, 2024 | 01:59 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
My welding skills are exactly the best in the world so should I try for a butt weld or would it be easier to just go with a lap weld. Pic below.
Old Feb 4, 2024 | 06:10 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: Floor Pan to Console Patch - Butt Weld or Lap Weld
Lap weld is going to be easier, and once you put down carpet and pad, nobody will ever know.
Unless you're using a wire feed, or something you can really regulate and control, why don't you just braze it?
Old Feb 6, 2024 | 08:16 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
I would butt weld that seam and plug weld at the inner rocker panel. For the butt weld, take your time, trim and line up the two panels as you stitch weld it. Grind the bottom of the butt weld, leave the top weld intact and seam seal the top weld before covering with carpet.
Old Feb 7, 2024 | 06:17 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
butt weld with full weld all the way around and then seam seal the seam is the correct method for metal repair. with that being said, a clean minimal lap joint with seam sealer is no different than any of the other lap joints that the entire car is made up of.
rkg8554
Fabrication
Jun 17, 2014 07:03 AM
nickyakker
May 6, 2013 10:16 PM
soarestransam
Sep 17, 2011 12:27 AM
Mokilok
Feb 14, 2007 06:35 AM
TwinTurboROC
Oct 16, 2003 09:23 AM
