Hood, fender, nose alignment
Old Oct 21, 2024 | 05:20 PM
rearview's Avatar
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
Have a look at these images... What can I do here? It seems the hood needs to go forward and maybe the the nose should come up more?
I've adjusted the nose as high as I can with the 4 screws on either side on the latch on the adjuster plate things... I've loosened the fender bolts to see if they move much to the rear (not really) and I've loosened the hood hinges to try to move forward. Thanks,
Slight misalignment on this side
Hood is more misaligned on this side
Gap because either the hood isn't forward enough, or the nose is low?
More of the gap
Old Oct 21, 2024 | 08:33 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Hood, fender, nose alignment
Hood needs to come forward a touch.
Old Oct 21, 2024 | 08:43 PM
rearview's Avatar
Yes but... How?
Old Oct 21, 2024 | 08:47 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You can loosen the bolts at the hinge and wiggle it forward a bit. Careful not to rock it as you could hit and scratch your fender.
Old Oct 21, 2024 | 10:09 PM
rearview's Avatar
As I said a above, I tried that... Maybe I remove the hood and try again that way... I had the hood and whole nose off for the LS swap... Though if I recall (it took a few years) it wasn't perfect to start...
Old Oct 22, 2024 | 04:46 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Try loosening the bolts that connect the hood hinges to the fender and move the hood & hinges towards the front of the car. I’m pretty sure there’s some adjustability there.
Old Oct 22, 2024 | 08:31 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I second this. It is a fine dance for sure and helps to have an extra set of hands. May require a fender adjustment too, but I found the fenders find their "home" easier than the hood.
88BLKTransAmGTA
Sep 26, 2023 11:41 AM
anesthes
Dec 29, 2017 09:50 AM
Dakota W.
Apr 15, 2013 05:51 AM
chazman
Jun 6, 2010 10:26 PM
StealthElephant
May 30, 2005 10:30 PM
