Door wiring and removal
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm removing the doors to replace the pins. Can you snake the door wiring out of the door instead of disconnecting it from under the dash? I have kick panel speakers and it's quite tight under there.
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: Door wiring and removal
No need to remove the wire harness from the doors when replacing the pins. You can accomplish this without disconnecting the wiring harness.
But to answer your question, yes you can disconnect all the connectors in the door (power locks, windows, electric mirrors) and then pull the rubber accordion from the door side and slide the wires out of the door.
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
