2 good questions
Old Jan 24, 2002 | 08:14 AM
88greyiroc's Avatar
2 good questions
the underneath of my car had a bit of surface rust so i took sand paper and sanded off the rust and then put some rust check over it then a layer of black rust paint then more rust check. i was just wondering if i could have done more harm then good how will i be able to tell if it was rusting again?or would that rust check stop the rusting or i mean prolong the rusting???and my other question is the top right part of my front seat belt is sticking really bad would i be able to just buy that part or would i have to buy the whole seat belt?and if i can are those quite expensive?
Old Jan 24, 2002 | 08:22 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
About the rust, I'm not sure if that will do more harm than good, but if you want to seal the rust completely, get some POR-15 (http//www.por15.com). You paint it on and it dries almost like ceramic and it won't peel, crack or chip. My car has no underbody rust and I'm gonna be putting 2 coats of POR-15 on it this spring to keep it that way. Good luck.
Old Jan 24, 2002 | 05:26 PM
88greyiroc's Avatar
anyone else wanna offer some advice?
Old Jan 25, 2002 | 03:13 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Don't forget to always use protection...
Old Jan 25, 2002 | 11:29 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
ha, you dont want to have an accident
Old Jan 25, 2002 | 11:35 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
POR-15
Caspar
Jun 19, 2016 11:19 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
