Cable vs. Electric Door Mirrors
Old Apr 3, 2025 | 08:41 PM
taguy16's Avatar
Are the electric left door mirrors more robust than the cable operated ones? My cable operated one was just wobbling around so I took it apart to try to fix it and it's a really cheesy design. I'm afraid if I get another used (since you can't buy new) cable one it isn't going to be much better. I thought I could switch to an electric one: I could just hook up a battery to adjust it, tuck the wires out of the way and then leave it be. I never adjust my left door mirror anyway unless it gets knocked out of position. I'm thinking the electric ones aren't likely to get knocked out of position.
I wish you could get one that adjusts manually, and not manually like GM called manual with the three tiny cables attached to a cheap lever.
Old Apr 3, 2025 | 09:19 PM
gp90gta's Avatar
Car: 1990 GTA
Re: Cable vs. Electric Door Mirrors
Never had a manual one but all the thirdgens I’ve owned had electric and never had an issue. You could just buy an electric one and instead of trying to wire it up just roll your window down and move it by hand, it’s not an issue doing this you will just hear clicking from the pins moving in the motor.
Old Apr 3, 2025 | 10:12 PM
taguy16's Avatar
That's good to know. Thanks.
Old Apr 6, 2025 | 07:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
How is the manual pass mirror adjusted, not by cable right? Maybe you could rig one up on the dr.side if you dont want the cable. Ive never had issues my power mirrors though.
sdryluth
Feb 27, 2024 05:30 PM
Mspangler
Sep 25, 2022 12:12 PM
86WS6
Dec 28, 2015 02:04 AM
genso
Jun 26, 2010 08:37 PM
John 89 Formula
Feb 18, 2002 05:26 PM
