Sealing ac delete box to firewall
Old Apr 9, 2025 | 04:33 PM
lakehoon's Avatar
Not sure if it falls under this category. But thinking of useing this rubber seal to seal ac delete box to the firewall. What you guys think? Worried about heat specifically .
https://a.co/d/4L30UgP
Old Apr 9, 2025 | 07:12 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Sealing ac delete box to firewall
There’s a seller on eBay that has the proper gasket for the heater box. Search “camaro heater box gasket”. It’s like $70 with shipping though.
Old Apr 9, 2025 | 07:19 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Homemade gasket, Post #1171, https://www.thirdgen.org/forums/ltx-...ml#post6293557
Old Apr 9, 2025 | 09:09 PM
gp90gta's Avatar
Car: 1990 GTA
Personally I would use butyl tape, specifically 3M windo-weld ribbon sealer.
Old Apr 9, 2025 | 09:58 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I used some 3M strip caulking. Works like a champ and has held up for over a decade.
Old Apr 9, 2025 | 10:16 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Factory used a diecut, closed cell adhesive backed foam
Old Apr 9, 2025 | 10:34 PM
lakehoon's Avatar
Here's the box I'm working with. It's not the cheap one for vehicles that weren't originally equipped with ac. I got the one from hawks/acdelete.com. it's actually fiberglass and has a lip that mates to the firewall and isn't flat all.the way around
Old Apr 16, 2025 | 12:34 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You got your thinking backwards. The stock metal housing is better.... as you'll find out when you try to install that fiberglass piece.
hwcoll95
Sep 20, 2011 02:10 AM
