rusty floor pan ideas
Car: 1990 Firebird
Engine: LS3
Hi all, sorry for the giant picture. it's been a while since I've posted, my car is coming back to life with an LS3 and a 4L60E. how bad does the collective think these floor pans are, and what would be a good way (short of replacement) be to address the rust?
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: rusty floor pan ideas
Tue majority of it looks like surface rust but i may be wrong. The pass side inner rocker by the front wheel looks questionable. The driver side front of the floor pan where it intersects the unibody looks questionable as well. Id clean it all up and figure it out. Shouldn't be anything too bad.
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Cut it out and put new steel in there
Car: 1983 Z28
Engine: 385 Fastburn
See what it looks like after some time with a wire wheel. May be able to get away with cleaning it up really good and coating it with some eastwood frame paint and then patch a few thin areas.
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
