Help Steering Wheel
Old Jan 31, 2002 | 09:25 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Help Steering Wheel
going to junk yard tomorrow and there is a 86 t/a with the 3 spoke steering wheel in it, can my friend put this into his 92 firebird with no problem? Hes willing to give up airbag (doesnt work anyway) and how the hell do i remove steering wheels from third gens, tried today but couldnt get it? please help
Old Feb 1, 2002 | 11:35 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
as far as if the wheel will fit. Im not sure but if you want to get the wheel of the 86 then you will have to use a steering wheel puller or once you get the horn cover off back the retaing nut off untill it if flush with the center bolt. grab hold of the wheel at 3 and 9 oclock and pull while a friend hits the nut and center bolt with a hammer. this will work sometimes if you dont have a puller.
also try wd-40 or something like that on the shaft before you try to get it loose.
Old Feb 1, 2002 | 03:14 PM
Drew's Avatar
It'll fit well enough to drive the car, but it'll probably rub the steering column and won't fit as far down on the splines as it should... In other words, its not worth bothering with.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
