taking out back seat
Old Feb 5, 2002 | 07:59 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
ok.. i know its possible.. when i went to take out the back of the back seat, i noticed there was a small space to get to the screw.. its a t30 screw. there is about a inch in front of it and my t30 socket is just longer than there is space. how do u get to the screws to take them out?!?!?!?!?!?!?!?!?!?
mike (loomdog)
Old Feb 5, 2002 | 08:41 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
try taking out the lower plastic piece on both sides of the seat. That should free up some room. From reason i don't remember having this problem at all, but i can't remember which portions of the interior were together when i put the seatback in. Hope that helps, at least a little
Eric
Old Feb 6, 2002 | 06:56 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
If I recall to remove the rear seat back its just two nuts in the lower corners. I think it helps to remove the butt portion too, just two nuts in the front.
Old Feb 6, 2002 | 11:25 AM
loomdog32's Avatar
Car: 82 Camaro Z28
hmmm.. ive done all of that. there is no plastic int rim pannels in the car and the "butt" part of the seats are already out.. i know where the screws are, i just cant get to them.. if i ever do get them out im gonna replace the screws with bolts so i can at least get it out with a wrench.
mike (loomdog)
Old Feb 6, 2002 | 01:24 PM
360Iroc's Avatar
you need to remove the nuts on the bottom corners of the seat
Old Feb 6, 2002 | 01:33 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Exactly. There is either a 10 or 13mm nut at the bottom corner of the seat nearest the outside of the car. Remove that and the seats pull off a rod that's welded to the middle hump. Super easy.
Fast355
Dec 2, 2016 06:33 PM
lee01
Apr 9, 2016 01:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
