front bumper removal<--- help
Old Feb 6, 2002 | 08:34 PM
Adam62083's Avatar
How hard is it to take the front bumper cover on and off a 92 formula?
Old Feb 7, 2002 | 01:12 PM
MILT's Avatar
Easy, but kinda PITA.
You have to remove the headlight assemblies and the center tray thing first (that's the only way I've done it anyways...) Then you can get at the nuts holding the fascia on on the sides (I think these are 10/11mm). There are also some bolts on the underside that are easy to remove. Installation is reverse of above, but you'll want to get new nut thingys for the side bolts...you'll know what I mean when you see them.
MILT
Old Feb 7, 2002 | 03:35 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Headlight removal isn't necessary, at least on the 85-90 style, and I doubt highly that the 91 mounts differently. You can reach the side nuts easily by removing the plastic inner fender and reaching in or using a long extention.
Old Apr 19, 2014 | 09:04 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Re: front bumper removal<--- help
Thread resurrection! I'm missing the two speed nuts/palnuts (whatever you call them) on my driver's side and tried an assortment of standard size nuts that I grabbed at the parts store. Yeah, no. either just a bit too small to thread all the way, or just too big and slide on the stud. Does anyone know which size (metric 10 or 11 is what previous poster stated) and more importantly WHERE I can get some replacements? I've been all over the fastener sites on the net and have yet to find any that resemble the ones on the passenger side. Any help would be appreciated!
Old Apr 22, 2014 | 07:26 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
time for me to AGAIN toot bruces horn....hawks third gen will sell you the hardware you need to reassemble it.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mikey8494
Aug 22, 2015 07:57 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
