How did you conect up your sender for electric fuel pressure gauge?
Old Feb 19, 2002 | 07:44 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have an Autometer Phantom electric fuel pressure gauge that I have still to fit. How did you connect the sender to a fuel supply? I'm thinking that the easiest way is to use the schraeder valve on the passenger side fuel rail. I'm thinking that those little AN fittings and maybe some steel braded hose could be used?? The threads on the sender are different from the ones on the fuel rail valve. Does anyone know the sizes I need?
Thanks for the help
Robert
Old Feb 19, 2002 | 09:53 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
i am getting ready to do mine tomorrow probably. by searching some of the older posts i came to figure that i need some 4an steel braided tubing with 4an fittings on each end and then a 4an to 1/8" NPT fitting for the end that will go on the sending unit. one thread said that the 4an fittings will hook right up to the schrader valve. guess ill find out tomorrow. first though i gotta find some fittings and hose.
Old Feb 19, 2002 | 10:30 PM
Blue502's Avatar
That sounds like how I hooked up my Autometer Phantom electric fuel pressure gauge. Pretty simple. I think I used some fuel resistant sealant on the threads, but its been awhile and I can't remember for sure (that might have been on the oil temp sender).
Old Feb 20, 2002 | 02:23 AM
Jza's Avatar
Jza
If you're going to hard-mount the gauge inside the car (rather than in the hood like some ppl do), I'd (personally) put the sender on the feed line somewhere so I could still hook up an FP gauge when I'm working under the hood (adjusting fuel pressure, chasing down problems, etc.). Although I suppose you could always just remove it whenever you do that.
Old Feb 21, 2002 | 11:34 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
That's what I did. I took the inlet fuel line to a tube fitting supply co. I had them cut it and swage a t-fitting in the middle. Lon
Old Feb 22, 2002 | 08:42 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the help guys. I'll have a look under the hood tomorrow and decide how I'll connect the little bugger.
Regards
Robert
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
