Removing the rear seats
Old Feb 20, 2002 | 11:54 PM
jcjohnston78's Avatar
I have a 92 camaro RS. I was wondering if anyone knows how to take the rear seats out and how easy it is.
I just wanted to check the boards first before i even think about looking at the seats.
Thanx
Old Feb 21, 2002 | 12:02 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Just a big bolt under the center of each seat. And then it's just velcro-ed on to the carpet from there. No big deal. 5mins to remove both...
Old Feb 21, 2002 | 12:06 AM
what just go in there, pull up the back seats and look for the bolts, i took a quick glancea little earlier today, and i didnt see any bolts
Old Feb 21, 2002 | 03:50 AM
scott's85T/A's Avatar
You didn't lookin the right place then,,,
seat bottom,,has one bolt,dead center,on the bottom,front of the seat,going backwards twords the back of the car, bolting it to the floor,and velcro holding the back,,,
then the top part has a bolt holding it on right in the outside corner of each one and the inside is held on to the pin that it welded to your car,once you get the bolt out just pull straight out from the side,(where it seems to be still held on)or if you have a 3 piece back seat the top piece is 1 piece with 2 bolts in it.One in each corner,and these are easier to get out with the bottoms out,but not imposable.
By the way I think 13 mm for all.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
