Overhead lamp
Old Feb 28, 2002 | 01:20 PM
Bluerocket's Avatar
Overhead lamp
My car was missing a over head lamp so I went to the 'yard and pulled out a over head unit with the map lights and was wondering if I could install it without modifacation.
Old Feb 28, 2002 | 02:50 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
there are 2 types I can think of, one has the whole console, the other there are just the 2 map lights.
I think you might have to run a ground wire for the map lights, I have not taken one apart, but you might need to run a "hot" wire up there use zip ties and tie it to the existing wires.
If you have the full console out of a salvaged car then you will have to cut some holes in your headliner, and run the wire as well...
I think thats all there is to it...
John
Old Feb 28, 2002 | 04:44 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Even if he has the one with just the dome and map lights, and the car originally had just a dome, he's going to have to cut the headliner. When I changed my headliner, board and all, and went to put in the map/dome light assembly, I was like wtf is wrong here?
Kinda sucked cutting a perfect headliner, but it came out ok.
Old Mar 1, 2002 | 07:58 AM
okfoz's Avatar
I did not know if the hole was any larger or not, since I have not taken apart my SC headliner as of yet to ****** the dome light.. I thought it might be the same, because the overhead console used the same hole back there as the normal dome light...
John
Old Mar 1, 2002 | 12:16 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
On headliners with the map lights, the hole in the headliner comes forward more. If you look at the front of the map lights, there's a metal tab that sticks out.
Old Mar 1, 2002 | 12:24 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
This should help. Not perfect, but gives an idea:
Old Mar 1, 2002 | 12:58 PM
Bluerocket's Avatar
thanks that helps because today I pulled the headliner out of the car I got the map ligts out of and it is the one that looks like the standerd dome light whith the map lights
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jetmeck
Sep 4, 2015 12:29 AM
