camaro turn signal
Old Mar 4, 2002 | 03:17 PM
silentneko's Avatar
camaro turn signal
hey guys, is there a way to take out the lens of the front turn/parking light, without cracking it, if not how do you clean the inside out.
Old Mar 5, 2002 | 06:25 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Easiest way probably is to drop the front of your lower valance. Look up in there, you should be able to see the two 10mm (I think) bolts holding each lamp in. Take those out. That's it.
Old Mar 5, 2002 | 09:16 AM
silentneko's Avatar
no, I have them out already, I need to know if you can take the clear lens off the plastic body of the turn signal
Old Mar 5, 2002 | 09:28 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You have to cut the seal with a razor blade then I think there is 4 tabs you have to pry loose. Clean them up and use silicon to put them back together. make sure you get a water tight seal.
I priced them at a local aftermarket autoparts store and they said they could get them for around 15 buck each. Which is well worth the money.
Be careful the lenses break easy. you may be better off buying new ones. If you cant afford new ones and you dont want to risk breaking them, try a foam glass cleaner. Spray it inside them then take a towel and screwdriver and dry it out.
This takes some time and wont get them as clean as if you took them apart, but it helps.
good luck!!
Old Mar 5, 2002 | 10:01 AM
silentneko's Avatar
well I bought the 2 of them for $12.60 at a junkyard and am going to sell them on ebay so I think I'll try it, if it cracks I'll buy another one, how much you think I can get for a digital dash from a berlinetta
Caspar
Jun 19, 2016 11:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
