Getting headlight knob off
Old Mar 5, 2002 | 04:14 AM
larsulrik1's Avatar
Getting headlight **** off
I'm gonna replace some bulbs in my 92 rs tomorrow. Last time I messed with the cluster I couldn't figure out how to get the headlight **** off to remove the outside bracket. Probably really simple but I'd like to know first to save time. Thanks.
Old Mar 5, 2002 | 08:34 AM
onebinky's Avatar
their is a small spring-loaded button on the side of the switch. push this button and pull the rod straight out. The button is kind of hard to get to, though. Its behind the dash panel, so you have to reach up and behind the dash if I remember right.
Matt
Old Mar 5, 2002 | 08:57 AM
riz75's Avatar
i just changed some bulbs 2 weeks ago. i ended up just pulling the **** off (probably not the best thing to do, but i was getting pissed ) . then i took the metal insert (in the ****) out and bent the tab out a little. everything was inserted nice and tight.
Old Mar 5, 2002 | 12:20 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Yup, I just pulled mine out also, it went right back in and I had no problems with it.
Old Mar 5, 2002 | 01:35 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
There is a button, it isn't all that hard to get to, just feel around the switch, that way you have dont' ahve to worry about the possibility of breaking something.
Old Mar 5, 2002 | 04:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Go to the parts store first and look at a new switch so you know what you're looking for.
Old Mar 5, 2002 | 07:48 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
if its not too late...all u do is take a small flat screwdriver and when looking at the switch it will liik like alittle tower sticking out of it...the only think sticking out...just press that in and pull the **** out
Old Mar 5, 2002 | 10:07 PM
larsulrik1's Avatar
Yeah I found it and I used it. What I found out though is that you need to pull it out to the lights on position before you push the button. At first when I held the button in with the lights off position, it wouldn't pull out. Thanks for the help guys.
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
