take the headliner off
Old Mar 5, 2002 | 09:57 PM
Slow2.8's Avatar
ok i want to take off my headliner, and i have t-tops, i took out the sunvisors, but then i reach a prob. it might sound easy to you guys, but im confused, how do i get the headliner off around the dome light?
by the way i want opinions, i have a saggin headliner right now
with a white camaro, and red int. i think takin the headliner off will look bettter with the t tops off and seeing something that looks like my paint color better then ripped fabric and yellow foam, what do you think?
Old Mar 6, 2002 | 06:31 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
You have to take the dome light off by removing the two metal clips on the studs. Use a small screwdriver or needle nose pliers to do this.
Old Mar 6, 2002 | 02:05 PM
Brak's Avatar
I just recovered my T-top headliner...........pretty much followed the Tech article provided here. Mine had some weak areas but the article tells how to use fiberglass cloth to repair and strengthen.
I bought new material for $30. It took a lot of time and didn't come out perfect but way better then the cracked areas I had with the tops off. I like to try things myself before buying new.
Plus, this way you can recover it any color you want.
Also, when I bought the material, it came with new clips to hold the light assembly in place.
Old Mar 6, 2002 | 09:15 PM
Slow2.8's Avatar
thanks alot mikes, that **** look tricy...i'll do it tommorow i think
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
PurelyPMD
May 5, 2016 04:57 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
