tilt column wobble
Old Mar 7, 2002 | 04:31 PM
jump6pack's Avatar
tilt column wobble
My tilt column on my 89RS started wobbling. You can move the column from the tilt portion to the steering wheel about 1/2 inch. Is there something inside the column that I need to tighten up? Or is this a sign that the column is ready for the scrapheap? Anyone have this problem before? I am new to the 3rd gen, but do have wrenching skills.
Old Mar 7, 2002 | 06:26 PM
gmanuel's Avatar
Follow this link to fix your problem https://www.thirdgen.org/newdesign/t...ngcolumn.shtml
Did mine and it was a PITA
Old Mar 7, 2002 | 06:34 PM
JAF's Avatar
JAF
According to the mechanic who repaired my 91 TA, the steering knuckle loosens due to pressure against the steering column when tilt is released improperly.
Fortunately, the dealer I bought my car from made the repair without extra charge, which took about four hours. The good news; no parts, just labor.
Old Mar 7, 2002 | 07:09 PM
kessler89/2.8's Avatar
Car: sold the Z now i'm drivin a 81 toyota celica and an 01 Suzuki TL1000R
Engine: 90degree 998cc V twin
Transmission: 6 speed
i took my whole colum out tightend some bolts (could only get to 2 of them) and put it back in. 2 weeks later i'm back to square 1 with a colum you can swivel in a 360 degree circle, if you see any for sale let me know
Old Mar 9, 2002 | 09:05 PM
2vmodular's Avatar
if the bolts you didn't tighten fall out of their holes, they can cause the steering wheel to bind when turning. is very difficult to safely drive a car when you can't steer it.
Old Mar 9, 2002 | 11:10 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
or shut off when driving! my friends 88 gta did that. I got to fix that one. it was so bad (broken) we got an older one and switched everything over.
Old Mar 10, 2002 | 12:48 PM
Drew's Avatar
Does anyone bother to search before posting anymore? This is a classic oldschool typical GM problem, its fairly easy to resolve if you're not a bonehead and have the appropriate tools.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
roysatikas
Sep 22, 2015 08:15 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
