How to Break into a third gen.
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Originally posted by jcurrieirocz
i found that some other thirdgen keys worked in the doors of other 3rd gens sometimes.
Yall can try, but my lock cylinders are still frozen for a reason.
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
Originally posted by ChillPhatCat
Where do you think I got my thirdgen
j/k
I carry two keychains at all time... one with ignition and door... the other just a spare door key... I've already had to use it just within a month of implementing the method... saved my *** from sitting frozen out in the parking lot waiting for extra key...
j/kI carry two keychains at all time... one with ignition and door... the other just a spare door key... I've already had to use it just within a month of implementing the method... saved my *** from sitting frozen out in the parking lot waiting for extra key...
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
just so everyone knows, you dont need a complex bent piece of wire, you need a ruler, plastic/wood/metal. just straight down above the lock. hell, one time i used a pamflet from the gas station, folded it ofer a couple of times.... damn...
Car: 91RS_92Z28
Engine: 5.0_5.7
Why not add how to hotwire pass keyed cars, oh wait that thread exists too.
NOTE TO THIEVES: None of these techniques work and you will be shot.
Re: How to Break into a third gen.
My car is retardedly easy to break in to. I locked myself out of it once and a guy from AAA came and used a piece of 1/4 inch rod bent like a 7 and slid it around my window and nailed the unlock button. Took a total of maybe 30 seconds to position it and press the unlock.
The best ttool that will work on every car, is the long metal rod , the one with a tee handle and a inch long 90degree finger on the other end. It is usually coated in a bright powder coat. And is used with a plastic wedge.
The other tools like the slim jim "A" either take too long or "B" only work on a few cars.
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
true. however not everyone has one of those in a house or from a store.. A coat hanger works very well on thirdgens.. I can unlock a thirdgen in less than 5 minutes with a steel coat hanger. does not really take that much effort once you figure it out the first time.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Who has the best alarm and how good is the VATS system?
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Car: 87' Camaro
Engine: 305 carbed
like mentioned above me, ruler gets you in in about 5 seconds....scary how easy it is.
this is why i disable my car anytime i go anywhere i have doubts about XD
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
When I locked my keys in my car at home I just found a long skinny rod and bent the passenger window back a little to get it in there, ran it through to the driverside and hit the unlock button. I don't have t-tops, its a hardtop. I hear that the 4th gen guys can just bent the window back and stick their arm in to unlock the car. Its scary how easy these cars are to break into.
yall realize that you can get in these cars in seconds with a butter knife right? stick in at the top of the window and pry outwards, stick one hand in and pull the window straight out, it will go out a good 3-4" inches so you can get your entire arm in...
its by far the quickest method for getting in the car.
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i used a flat head screwdriver and it turned the key lock in the door
was in the car in 2seconds
I locked the keys in one of my parts cars once, and I found all you need to do is pull out the side window slightly, and use the radio antenna to unlock the door.
I can get into any 3rdGen this way in about 20-30 seconds. T-Top cars are easier for some reason with this method.
I have used this method 8-10 times now over teh last 10 years to get into my own cars, my 88 Camaro Hardtop I locked the keys in 4 times, My Formula T-Top once the night before a Car Show I locked the keys in, my Friends 91 RS Hardtop we locked the keys in at a Toy Show
Car: 1985 trans am
Transmission: t5
third gen keys also work in excorts lol my sister locked her keys in when she put it in the ditch so i pulled up pulled out my keys unlocked the car n started it right up wit my firebird keys lol oh and another way is take a slotted screw driver and put it in the door lock n twist and BAM open door
sjorgens
Oct 1, 2015 07:54 PM
Nikole
Sep 24, 2015 08:12 PM
