Major cracks and peeling under wheel well
Old Mar 30, 2002 | 11:45 AM
86BIRD-MY FIRST CAR's Avatar
i can litterally chip this stuff (the material and paint) away with my fingers. how can i fix this with out buying a new wheel well. Any spray type thing i can use.
Old Mar 30, 2002 | 01:58 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Are you talking about the inner plastic fenders, if so go to a junkyard and get some. all you need is a pair of wire cutters to pull out the plastic pop clips, and a 7mm nutdriver. (Its easeir if the car has no wheels btw...
I took mine and scrubbed them up really good then I painted them (a previous owner ran over some wet road paint)
Oh DO NOT CUT THE POP CLIPS OFF, simply put the cutters on either side and pry out.
hope that helps..
John
Old Mar 30, 2002 | 05:13 PM
I dont see plastic, the wheel sits right below it, u can hear all the the water splashing when it hits it, u know that curved under part of the fender. thats all peeling and cracking
Old Mar 30, 2002 | 08:21 PM
3gc's Avatar
3gc
Car: Z28
It depends, if your talking about the front or the rear. In the front you can replace the "wheel well", it's the plastic inner fender that Okfoz was talking about. I don't know what lines the rear wheel wells.
Old Mar 31, 2002 | 12:00 AM
its the rear ones
Old Mar 31, 2002 | 09:42 AM
Tonyrodz's Avatar
Transmission: auto
Is it a rough surface? I think that might be some kind of undercoating--it covers the metal in the wheel well. Should be good metal under there--unless the car was rearended hard.
Old Mar 31, 2002 | 02:01 PM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
I have the same problem. It's a seam sealer that dries out with age. I'm going to remove the old stuff, re-seal it and then undercoat the wheel well.
Old Mar 31, 2002 | 02:08 PM
What type of undercoat and sealer should i use, so its ok if i peel all this crap off...
Old Mar 31, 2002 | 02:16 PM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
There are 2 types that I know of. One is in a caulking tube and the other is in a quart can and is supposed to be brushed on. I have to read them better to see which to use. I'm just using plain old rubberized undercoating. Worst part is going to be making sure the old surface is grease/oil/crap free before applying new stuff.
Old Mar 31, 2002 | 07:45 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
3M makes some decent undercoating in a can. I bought a 25.00 air gun and now use Morton Truck bed liner on everything.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scamo-2.8
May 20, 2016 07:01 PM
z28_AJ
Aug 27, 2015 08:59 PM
stalkier
Aug 21, 2015 01:54 AM
