Here are the pics of the triple pod filled as well as the 4th gen steering wheel
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here they are, hope you like them.
Motor is toast, looking for a 350 to slap into her.
Well, running very very rich for 2 months wore out the piston rings causing major blow-by. I get clouds of smoke billowing out of my valve cover breathers when I rev up the motor.
I have one or two rod bearings that went bad from age, running the car hard with about a quart of oil in the motor, etc....
My Oil Pressure gauge usually sits at 27psi most of the time and a few times it would drop to the red and a couple of times when I'd corner it would hit 0 psi. I was leaking 1-2 quarts every other day or so. The leaking was from all the pressure in the crankcase from the blow-by and leaking from the valve covers, dist. hole, oil sender fitting, and some other small places.
I drove the car tonight and thought it wasn't going to make it home. Almost rear ended my friend in his 95 Supra TT when the motor stalled and I lost my brakes.
Looking for an inexpensive 350 to slap into the car.
1992rs/ss
16
Jan 28, 2016 09:58 PM
backtothe80s
Sep 5, 2015 12:39 AM
