Brights
Old Apr 2, 2002 | 05:44 PM
BlueAlice91bird's Avatar
Brights
What gives? My brights won't switch on or off unless I push my steering column all the way down, I can't drive like that, not to mention it won't stay in this position. Anybody got any ideas?
Old Apr 2, 2002 | 07:00 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
You probably got a loose wire...
Old Apr 2, 2002 | 08:41 PM
Nope, no loose wires, been under there and it's like the actuator rod is only long enough for when it the steering wheel is at it's lowest. Actually it's gotten worse, it used to just take pulling it just right, now......
Just wondered if anybody else has run into this problem and fixed it.
Old Apr 2, 2002 | 08:58 PM
JAY4SPEED's Avatar
There is an extension on the dimmer rod. Its made of plastic and get brittle when it gets old. Your dimmer switch directly contacts this rod extension and the plastic rod extension pivots on the actual dimmer rod when the column is tilted. I'd check that. You may also be able to adjust your dimmer switch near the base of the column, it could have been knocked out of adjustment possibly.
F-body-fan
Jan 12, 2023 01:49 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
dbrochard
Sep 25, 2015 04:56 PM
gta_knight
Sep 17, 2015 03:48 PM
louishenry
Aug 28, 2015 09:41 AM
