antifreeze tank
Old Apr 3, 2002 | 03:44 PM
Camaro1991RS's Avatar
antifreeze tank
I'm about to paint under the hood of my car and was wondering if anyone knows how to take the antifreeze tank and washer fluid tank off.
Old Apr 3, 2002 | 05:39 PM
ihateallmustangs's Avatar
there is a bolt under the wheel well in the top left corner of the anitfreeze tank. it screws from the underneath up into the tank.
Old Apr 4, 2002 | 02:30 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I have an 1987 Firebird, so mine could be different, but....
My 2 reservoirs were just held in with plastic push in pins with retainers. There were 2 on each unit. They are hard for me to describe, but i will try.
They work like the screw retainers you use on sheetrock walls.
There is a pin that slides into a retainer that has legs. It is one unit. As the pin pushes in the legs expand and lock the retainer in place. I just got a screw driver and popped the head back up. When it was backed out fully, the retainer slides out of the hole.
Now I have seen some that have phillips screw heads and you screw them out of the retainer.
On my car, I was able to get to them from above, not from in the wheelwell.
Old Apr 4, 2002 | 05:06 PM
mudaholic's Avatar
85 iroc here, and mine were the same as redraif described..
Old Apr 4, 2002 | 11:04 PM
Kandied91z's Avatar
i also agree with the above, by the way new tanks greatly enhance the looks!
Kandied91z's Avatar
and for the new ones!!
:lala:
Old Apr 14, 2002 | 12:54 PM
MNformula350's Avatar
i do not have those kind of tanks anymore,
i removed them and replaced them with one from a 91 Explorer both the antifreeze overflow and washer fluid are combined into one bottle that is about as big as a battery is wide and long
looks great!
But to your original question in my 90 Formula the overflow bottle there is one bolt that needs to got to from the wheelwell.
Old Apr 14, 2002 | 04:57 PM
RODS92Z's Avatar
Yeah those new ones really make a difference in appearance. I just put a new one on my car last night. What a difference.
Old Apr 14, 2002 | 08:59 PM
89Formula305's Avatar
The one on my 89 is in the wheel well, I went to take mine out and the screw was just turning so i had to rip it out and get a newone...atleast i have a clean one
Old Apr 14, 2002 | 09:52 PM
3gc's Avatar
3gc
Car: Z28
Kandied91z can you give me a part number for the washer fluid resevior. And is it the one with the fluid pump in it? I tried searching but I couldn't find it. And the number that the Parts and Illustration Catalog gives can't be found on gmpartsdirect.com.
Old Apr 14, 2002 | 11:43 PM
Kevs86TA's Avatar
Car: 86 Trans AM
Hey Kandied91z where did you get your air inductiob from?
Old Apr 14, 2002 | 11:44 PM
Kevs86TA's Avatar
Car: 86 Trans AM
oopppss i mean induction.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
kx3g
Sep 28, 2015 08:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
bryan623
Sep 19, 2015 10:13 AM
