key will not turn
Old Apr 8, 2002 | 08:23 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
key will not turn
i have an 86 camaro. the key will not turn backwards to supply power without having to turn the car on. can it turn backwards? and how do i fix this problem?
Old Apr 8, 2002 | 08:40 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yes, it should turn backwards. You are probably having a switch that is going bad. The only way to fix the problem is to replace it. I've replaced a few and it's fairly inexpensive. They run about $20, unless your's has a chip in the key, then it's like $50. It's not that hard to replace either.
Old Apr 8, 2002 | 09:30 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
chip? i dont know if it has one. can u send me instructions on how to fix? all i know is it is an 86 z-28. i has the 305 with the rochester 4bbl. it is computer controlled.
Old Apr 8, 2002 | 10:17 AM
CraZ-28's Avatar
Car: 1991 Z-28
Actually, since you have an 86, you don't have the chip. The installation in pretty easy. I don't have any pics though. Basically you need to pull the stering whell and remove the plate underneeth(spelling?), you'll need to get a special tool for the job($12 at autozone). Next is to remove the electronics, 3 or 4 screws. At last there is 1 screw holding the switch in place. Pull it out and put put the new one back in. Then put things back together. If you have a haynes manual, it will show pictures and give a better explanation. I did my first one without a manual, it's that easy.
Good luck!
WIzmo
Aug 30, 2015 02:30 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
