Turning off 91 Shift light in manual cars?
Old Apr 9, 2002 | 03:31 PM
bluehog67's Avatar
Car: RS
Transmission: 5 speed
I was wondering if there is a way to turn off that Damn "SHIFT UP" light in any Camaro's that have a manual tranny after 1990. If I put White gauge faces on, will that at least cover up the light ? I'd rather shut it off though. If anyone knows please post.
Old Apr 9, 2002 | 03:55 PM
JPrevost's Avatar
Car: 91 Red Sled
Just remove the light bulb when you take the guage pod out.
Unless you burn your own eproms you can't change the shift light but since you said you just wanted to get rid fo it....pull the bulb.
Old Apr 9, 2002 | 03:58 PM
cort351w's Avatar
if you do burn your own proms, as I plsn yo in the future, could you change the rpm at which the light comes on?
Edit: I mean as I plan to do in the future.
Man, I really couldn't type this afternoon--"plsn yo do"
maybe I meant to say
Waz up my nizzle! I beez plizzanin to bizzurn some prizzoms, yo.
http://www.ebaumsworld.com/thug.html
Old Apr 9, 2002 | 04:36 PM
bluehog67's Avatar
Car: RS
what the hell is an eprom ?? never heard of it , is that slang for something ?
Old Apr 9, 2002 | 04:40 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
E.raseable P.rogrammable R.ead O.nly M.emory.
It's the chip that your ECU uses to store the data which it uses to meter fuel, control spark, lock up the torque convertor, etc.
Old Apr 9, 2002 | 05:02 PM
JPrevost's Avatar
Car: 91 Red Sled
Yes
Old Apr 9, 2002 | 05:43 PM
cort351w's Avatar
If you changed the rpm and took off the arrow pattern or cut out a circle arround the arrow or whatever (so that you see more of the light), AND put in a brighter bulb, the shift up light could be used as a shift light?
Old Apr 9, 2002 | 05:52 PM
bluehog67's Avatar
Car: RS
so how do you burn your PROM and why would you do it besides turning off the "shift up" light ?
Old Apr 9, 2002 | 07:06 PM
cort351w's Avatar
check out the tech article on prom burning and see the post above
the entire diy prom board is devoted to the subject
Old Apr 9, 2002 | 10:03 PM
bluehog67's Avatar
Car: RS
cool thanks
1992 Trans Am
May 10, 2023 07:19 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
dhonda200
Aug 11, 2015 11:50 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
