Vinyl is separating from center console on the sides
Old Apr 12, 2002 | 01:14 PM
86BIRD-MY FIRST CAR's Avatar
how do i fix this, looks horrible !
Old Apr 12, 2002 | 04:18 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Mine did it too. I took out the center piece around the shifter and put some glue with a strong bond. I put it in between the vinyl and plastic. I good some wood and placed it on either side of the console to hold the vinyl in place. I got some clamps and clamped it down. Left it overnight. And took the contraption off. It helped, but its not perfect. The wood keeps the glue from dimpling the vinyl where the clamp is. It holds teh vinyl evenly across the console.
Old Apr 12, 2002 | 04:19 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
You can try and band-aid it with epoxys or glue but really the only fix is to get a new one.
Old Apr 12, 2002 | 04:23 PM
sIcK pUpPy's Avatar
I pulled off the center cover and used teeny, tiny, finishing nails to hold it in place. Looks good as new and is still holding after two years.
JD
Old Apr 12, 2002 | 05:56 PM
lasersi's Avatar
Only real permanent fix is to use a Plastic Welder! It isn't cheap!
$240. from eastwoodco.com If you do buy one, I am sure many people would be interested in having you fix theirs. Good luck!
Old Apr 12, 2002 | 11:51 PM
russ84HO's Avatar
Has anyone on here just omitted the console from their car? I am considering taking the console out of my 1989 GTA, and relocating the power windows to the door panels. I just wanted to see if anyone has a car without the console.
russ
Old Apr 13, 2002 | 09:52 PM
Tony86TA's Avatar
SUPER GLUE...........
It works........
Old Apr 14, 2002 | 12:44 PM
MNformula350's Avatar
I used 3M emblem and trip adhesive with vise grips to hold it overnight and it still looks good 4 years later.
Old Apr 14, 2002 | 04:46 PM
Kaps's Avatar
Dave, was it glue or tape?
Old Apr 14, 2002 | 08:17 PM
Tom Keliher's Avatar
I did similar to other posts here: I used 3M Weatherstrip Adhesive. I applied it to the console, when it was removed from the car. Working the adhesive well into the sides of the console, I then used large flat pieces of wood and c-clamps to apply even pressure to both sides of the console. I let it dry for 24 hours. The wood made slight impressions in the vinyl, but another day or so and they smoothed themselves out. It has been a year and a half so far and is still holding perfectly.
Old Apr 14, 2002 | 08:54 PM
89Formula305's Avatar
Russ84HO, Im considering that also on my 89 formula but I have to find a place to relocate the power mirrors also.
Old Apr 14, 2002 | 10:23 PM
86 Trans AM's Avatar
Why not just get a 4th gen center console?
Old Apr 14, 2002 | 10:53 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
I used those short black trim screws with the donut shaped collar (washer). Space them evenly, drill a pilot hole first, and it looks great.
Old Apr 15, 2002 | 02:48 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
DITTO.......Super Glue. I dissasembled the center console and used small drops of SG to hold the vinyl back onto the plastic. Has held up fairly well.
Old Apr 15, 2002 | 11:50 AM
Chet's Avatar
Car: GTA
Super Glue worked for me too. It's also easier to fix if the console is out of the car.
:hail: :hail: :hail: Super Glue
Old Apr 15, 2002 | 04:05 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
4th gen console....
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Firebird sweden
Aug 16, 2015 05:02 PM
