sand/painting rear window louvers
Old Apr 13, 2002 | 02:37 PM
dwish8990's Avatar
so i spent last night sanding down my louvers, then priming them, then painting with flat black as someone suggested on the board here. umm.. well the paint turned out looking more like GREY then black. is that what flat black is supposed to look like? i thought it was just black without the shine. I'm thinking of redoing it with jet black or black glossy. the reason i didn't want the shine was because i thought it would make all the little imperfections show.. but since it came out looking like a dark grey.. i figure try the glossy black? i used sears enemal spray paint.
Old Apr 13, 2002 | 11:16 PM
Bluerocket's Avatar
I think the problum is that you put down to light of a caot and the primer is showing trough. Try puting a secound coat on.
Old Apr 14, 2002 | 01:33 AM
dwish8990's Avatar
could be... i used a grey primer so i could see where the actual paint was being sprayed. thanks..
Old Apr 15, 2002 | 11:03 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Yeah, try using more coats of flat black. If that doesn't work, I would recommend trying this: Use gloss black paint, but hold the can around 1-1.5 feet away from the surface while painting. This way, the paint is more dispersed once it reaches the surface and there is less "gloss". Note: The paint will be used up more quickly, so you may want to buy twice as much. However, if done correctly, it will look really good. But, just my 2cents.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
